Q: Is laminating over existing plastic laminate an acceptable practice? If so, what is the best procedure?
A: Jeff Pitcher responds: It is possible to add a second layer of laminate, though it’s always best if you can remove the existing laminate and get down to a clean substrate. Unfortunately, there’s really no good way to get old laminate off unless it’s loose to begin with. If so, by using a torch and a putty knife, you may be able to remove what...
