A.Chip O’Rear, assistant executive director of the National Tile Contractors Association, responds: Particleboard, which easily absorbs moisture and is dimensionally unstable, shouldn’t be included anywhere as part of a tile substrate. In this case, the existing plywood and particleboard subfloor layers will have to be removed and a new subfloor installed on the joists.
The best subfloor for a backerboard and tile installation is 3/4-inch plywood, glued with subfloor adhesive and mechanically fastened every 8 to 12 inches in the field, and every 6 inches on the edges. Leave a 1/8-inch gap between plywood sheets for expansion relief. Then install your 1/2-inch backerboard in a freshly combed bed of thinset (to...
