Resilient Flooring
JLC Field Guide: Resilient Flooring
Sheet resilient flooring tends to perform better than resilient tiles, especially in wet locations and heavy traffic areas where the seams between tiles can soak up water and trap dirt.
Learn More
Resilient Flooring Featured Articles
Underlayments for Resilient Flooring
With resilient flooring, the choice of underlayment is critical. This guide to selection and installation will help you get good performance. More
Quality Vinyl Floors
A professional floor installer describes the best methods and materials to use for a durable resilient floor. More
Working With Self-Leveling Floor Underlayments
Flatten uneven subfloors quickly with these pour-inplace compounds. More
Dressing Up The Garage
A high-tech floor coating, slat wall, and cabinets transform a single-car garage... More
Testing for Moisture In Concrete Slabs
Before installing flooring over concrete, do a calcium chloride test to make sure... More
A Door in Disguise
This bookcase masks a hidden storage closet. More
Making the Most of a Narrow Bathroom
Raising the ceiling and tweaking the floor plan opens up a cramped space. More
View All >
Resilient Flooring Instruction
Treat or Replace Pet-Stained Subfloor?
Should subflooring that has been stained with dog urine be torn out and replaced before a new hardwood floor is installed? More
Installing Hardwood Flooring over Vinyl
Hardwood flooring can be installed over existing sheet vinyl if key conditions are met More
Best Underlayment Fasteners
Q : When we install vinyl flooring, we like to fasten the underlayment with... More
Choosing Kneepads
For greater comfort, look for pads that fit the work you do and try before you buy. More
Best Flooring for a Humid Climate
Q: I'm planning on installing laminate flooring on the first floor of my North... More
View All >
