The article "Hot Water Circulation" (12/10) left me confused. First, it states that pumps must be correctly sized or pipe corrosion might occur - something I have seen firsthand. But then it goes on to state that when using a tankless water heater, you should go to the largest pump available - hence my confusion. Does the tankless system somehow negate the corrosion problem? Also, is corrosion a problem with PEX piping?
Randy Matthews
