Domestic Hot Water
Efficient Hot-Water Piping
Smarter layouts and right-sized pipes save time, water, and energy More
Troubleshooting: Water Heater in a Crawlspace
Vertical limitations and code requirements make it difficult to impossible to... More
Installing On-Demand Water Heaters
Compact tankless water heaters free up valuable space and save energy, but sizing... More
Condensing Storage Water Heaters
These heaters are up to 96 percent efficient and typically easier to retrofit than... More
Ultimate Electric Hot Water Heater Setup
Matt Risinger combines a heat pump water heater and high efficiency storage tank... More
Electric Water Heating for a Low-Load Home
Installing an electric tankless water heater proves to be cost-effective and... More
View All >
Domestic Hot Water Instruction Articles
Winterize & Maintain Your Tankless Water Heater
Tankless water heaters are fantastic units but they do need more care &... More
Maintain your Tankless Water Heater, or ELSE!
If you have hard water and use a tankless water heater, sooner or later you will need to flush your unit. More
Q&A: Noisy Expansion Tank
Q: Even though I followed the manufacturer's specifications when I installed the 2-gallon thermal expansion tank and check valve for my customers' domestic hot-water system, they still complain of "clicking" noises, mainly during the heating season. Does More
Proper Water-Heater Temperature
Q: I recently learned that building codes in my state now require that newly... More
View All >
