A.Master electrician Sean Kenney responds: The short answer is yes. Although the NEC does not require either the switch or the light fixture to be GFCI-protected, most lighting fixtures designed for use in a shower stall require GFCI protection to meet UL requirements. Providing GFCI protection for a switch within reach of a shower stall is a good safety practice, even when not required by code.
It’s worth consulting your local inspector before you locate a switch within reach of a shower stall. Even though the NEC allows such an installation, two inspectors have made me move switches so they were out of reach of the shower stall.
