Water Supply
JLC Field Guide: Water Supply
Plumbing codes divide a house's water supply into two parts: the water service and the water distribution.
Learn More
Water Supply Featured Articles
Getting Water From a Well
Dependable rural water supply starts with sizing the pump and using high-quality fittings. A master plumber explains the details. More
Sizing Domestic Water Pipes
A master plumber provides a step-by-step method for sizing water supply pipes, based on code and common sense. More
Efficient Hot-Water Piping
Smarter layouts and right-sized pipes save time, water, and energy More
Hot-Water Circulation Systems
On-demand systems install quickly and can save both water and energy. More
Retrofitting A Whirlpool Tub
A bathroom renovation specialist explains how to select and install a jetted tub... More
View All >
Water Supply Instruction Articles
Wastewater Heat Recovery Systems
Here’s how to make it less expensive to take a shower. More
Installing Water Service Lines
Connecting a Dishwasher Drain Hose
Is it better to run the dishwasher drain into the kitchen sink drain or directly into the waste line? More
Tags: Plumbing, Kitchen, Appliances, Drain Entrapment, Drainage
Venting a Sewage Ejector Tank
What is the proper way to vent a system that uses a sewage ejector tank? More
Q&A: Polyethylene Water Service Pipe
Q: I would like to use black polyethylene water service pipe for plumbing in the crawlspace of a house that has a black poly service line. Are there any code limitations on using polyethylene pipe? More
View All >
