A.A vapor retarder and air barrier will keep the moisture in the living area from being pushed into the wall cavities. While it would be better if there was a vapor retarder in the ceiling as well, it is much easier to ventilate the attic to avoid moisture problems than to remove moisture from the wall cavities.
