To make room for the cricket, the author strips the roofing around the chimney.
When the call came to check out a leaking chimney, it didn’t take long to find the problem. Measuring nearly 7 feet wide, the chimney sat like a dam at the bottom of a steep roof, with no cricket to divert water around the sides. The existing flashing and counterflashing were poorly installed and had little chance of keeping out moisture.
To remedy a situation like this, I strip off the roofing around the chimney and tear out the old flashing. After repairing any damage to the sheathing, I install the cricket that should have been there in the first place, then flash everything with new copper. This project was no exception.
