Metal Panels
JLC Field Guide: Metal Panels
Traditional metal roofs are made from flat-lock metal and site-formed standing seam panels. However, the increasing majority of metal roofs are made from several types of pre-fab panels, including screw-down, ribbed panels (similar to those used on agricultural buildings), and “modular” metal panels that mimic shingle, shake, and tile roofing.
Learn More
Low-Cost Metal Roofing
A metal roof specialist describes how to select the right agricultural-style roof panels for residential use. More
Installing a Flat-Seam Copper Roof
Old-school metal still works as a premium roof option. More
Soldering Seams
Regardless of the iron or tip used, soldering requires some prep work. Make sure that the tip is clean and that the four facets are flat and meet at a sharp point. More
Restoring a Standing-Seam Roof
Properly maintained, this elastomeric coating can protect a metal roof indefinitely. More
View All >
Metal Panels Instruction Articles
Tinning Copper Roofing Panels
Is this step needed when soldering copper? More
Metal Siding and Roofing – 10 Reasons It’s Awesome
While common for roofs, metal panel as not so common for siding. But there are... More
Cutting Metal Roofing
What tool works best? More
Fastening Metal Roofing
Could fasteners being driven through the valleys of the metal corrugation be the... More
Aluminum Roofing
Q: How common is aluminum standing-seam roofing? It seems that this profile would be better suited for heat-related expansion and contraction than corrugated aluminum panels fastened through their face, but my local suppliers carry only steel standing sea More
View All >
