A.According to the National Roofing Contractors Association, the minimum slope for a concrete one-piece barrel tile or interlocking flat-ribbed tile is 4:12. For flat shingle tile, it is 5:12. The CABO One and Two Family Dwelling Code prohibits the installation of any concrete tile on slopes less than 3:12, except with the permission of the building official.
The best precaution is to use some other type of roofing on the low slopes. However, if a uniform appearance is desired, a double-layer of 30-pound roofing felt, set in mastic or hot asphalt, must be laid over the sheathing and under the tiles. This effectively forms a waterproofing membrane. The concrete tile would then be cosmetic and would...
