All articles referenced in the JLC Field Guides may be viewed free of charge by the original purchaser of the book. Access an article by finding the chapter and page on which it is referenced, and then clicking on the article title. (Articles are in PDF format.)
Chapter 1
PageArticle Title
Issue Date
6Avoiding Foundation Failures
7/96
10Compacting Problem Soils
4/97
12Hillside Foundations, Part One
3/93
12Hillside Foundations, Part Two
4/93
18Rural Driveways
6/90
26Concrete Basics
6/00
26Ordering Ready Mix
5/02
30Ordering Ready-Mix Concrete
3/89
38Footing Fundamentals
10/00
40Fast Forming for Stepped Footings
3/94
44Rebar Tips
7/94
48Installing Seismic Framing Connectors
7/93
48Tying Down the House
9/97
50Seismic Support for Old Foundations
4/97
52Designing Concrete Basement Walls
4/02
56Concrete Block Foundations
10/93
66Waterproofing Basement Walls
9/02
66Spray-Applied Foundation Waterproofing
7/99
66Foundation Waterproofing Options
3/95
68Foundation Drainage
3/99
72Backfilling Basics
10/94
74Slab-On-Grade Foundations
4/95
76Layout Under the Slab
12/00
76Foundation Layout by Transit
3/91
82Post-and-Pier Room Additions
7/94
84Trouble-Free Foundations for Expansive Soils
11/02
86Frost-Protected Shallow Foundations
9/96
86Shallow Foundations: Beating the Frost
3/90
92Troubleshooting Low Retaining Walls
5/93
94Low Retaining Walls
3/88
94Troubleshooting Low Retaining Walls
5/93
94Practical Engineering: Interlocking Block Retaining Walls
5/94
96Radon Vent Retrofit
12/01
Chapter 2
PageArticle Title
Issue Date
98Estimating Rules of Thumb
3/96
100Unit-Price Estimating
4/94
100Unit-Pricing Pitfalls
7/99
102Framing Details for Wood Shrinkage
4/96
104Rating OSB Performance
2/94
112Practical Engineering: Using Metal Connectors
5/97
118Practical Engineering: Misplaced Load Paths
4/96
118Solutions to Common Framing Problems
6/98
126Framing Floors with I-Joists
4/02
130Framing with Floor Trusses
4/93
138Framing for Corner Windows
4/97
140Straight Talk About Hip and Valley Rafters
5/94
154Roof Framing with Wood I-Joists
1/97
158Installing Hip Roof Trusses
6/97
158Building Truss Roofs the Safe Way
12/01
160Truss Bracing Tips
3/94
160Truss Roofs Production Style
5/99
164Practical Engineering: Permanent Bracing for Piggyback Trusses
3/98
166Shear Wall Basics
1/93
166Tying Down the House
9/97
168Practical Engineering: Shear Nonsense
7/98
170Practical Engineering: Resisting Wind Uplift
1/97
174Air-Sealing the Story-and-a-Half
8/95
178Energy-Efficient Cathedral Ceilings
2/97
178Cathedral Ceiling Solutions
8/91
180Practical Engineering: Solve It with Steel
1/95
180Practical Engineering: Attaching Steel Beams and Columns
2/97
182Steelwork in Wood Frames
4/92
184Flitchplates
9/92
186-208How to Use Span Tables
4/94
Chapter 3
PageArticle Title
Issue Date
210Estimating Roofing Without Leaving the Ground
5/89
212Choosing an Asphalt Shingle: Organic vs. Fiberglass
5/93
212Have Asphalt Shingles Improved?
7/01
214Leakproof Details for Shallow Roofs
5/94
214Asphalt Shingle Q&A
5/02
218Reroofing Over Asphalt Shingles
5/99
222Long-Lasting Wood Roofs
5/97
222Wood Shakes and Shingles
10/92
224Protecting Wood Roofs from Fire
8/94
232Roofing with Concrete Tile
5/01
238Roof Tile Fasteners for High-Wind Regions
5/96
246Restoration Primer: Flat Lock Metal Roofing
9/87
248Restoration Primer: Standing-Seam Roofs
5/86
250Low-Cost Metal Roofing
6/92
252Metal Roofing Options
1/03
252Installing Metal Panel Roofs
5/00
254Sealing and Flashing Metal Roofs
1/00
254Watertight Skylights in Metal Roofs
4/97
260Slate Roof Repairs
5/88
262Leakproof Details for Shallow Roofs
5/94
264Installing EPDM Rubber Roofs
11/96
264Torchdown Roofing Basics
8/01
266Low-Slope Reroof with EPDM
11/00
266Building a Deck Over Living Space
5/02
274Bending V-Crimped Valley Flashing
8/99
276Flashing a Leakproof Valley
3/98
278Building Doghouse Dormers
10/94
280Flashing the Tough Spots
5/95
280Flashing a Chimney the Right Way
11/92
282Troubleshooting Roof Leaks
10/99
284Durable Exterior Details
6/99
286Low-Profile Ridge Vents
5/92
286Venting Details for Cathedral Ceilings
12/96
288Preventing Ice Dam Leaks
3/95
Chapter 4
PageArticle Title
Issue Date
296Water-Managed Wall Systems
3/03
296Making Walls Watertight
12/95
298Choosing a Sheathing Wrap
8/00
298Wrapping the House: Do's and Don'ts
3/00
300Choosing Flexible Flashings
6/01
300Controlling Moisture in Mixed Climates
8/97
300Avoiding Moisture Problems in Cooling Climates
10/97
302Water-Managed Wall Systems
3/03
302Making Walls Watertight
12/95
308Guide to Galvanized Nails
11/94
310Exterior Trim that Lasts
4/94
312Exterior Trim: Design Basics
7/95
318Economical Wood Siding
6/91
322Water-Managed Wall Systems
3/03
322Rain Screen Siding Retrofit
4/98
324Troubleshooting Wood Siding
6/93
324Working with Preprimed Wood Siding
2/00
332Builder's Guide to Vinyl Siding
6/00
336Aluminum Trim for Vinyl Siding
4/99
336Durable Details for Vinyl Siding
6/97
340Builder's Guide to Vinyl Siding
6/00
342On-Site with Fiber-Cement Siding
1/98
342Cutting Fiber-Cement Siding
4/03
344A Hard Look at Hardboard Siding
6/90
346Water-Managed Wall Systems
3/03
350Stucco Flashing Details
10/98
354Extreme Stucco
2/97
354One-Coat Stucco
6/95
358Installing Water-Managed Synthetic Stucco
9/98
358Success with EIFS
11/01
360Patching Stucco
9/97
362Getting Started with Brick Veneer
11/97
368Brick Veneer Basics
6/94
370Restoration Primer: Repointing Brick Masonry
7/90
370Restoration Primer: Repointing Pointers
8/90
374Making Paint Stick to Wood Siding and Trim
9/99
376Latex Enamel Problems and Solutions
1/97
378Keeping the "Natural Look" of Wood Siding
4/92
Chapter 7
PageArticle Title
Issue Date
128Controlling Moisture in Mixed Climates
8/97
128Avoiding Moisture Problems in Cooling Climates
10/97
128Vented vs. Unvented Roofs: The Great Debate
1/96
130Cathedral Ceiling Solutions
8/91
130Venting Details for Cathedral Ceilings
12/96
134Getting the Most for Your Insulation Dollar
10/96
134Wet-Spray Cellulose Insulation
8/94
134Fiberglass vs. Cellulose: Making the Choice
9/95
136Getting Quality from Fiberglass Insulation
7/02
136Insulating with Spray Cellulose
10/01
136Wet-Spray Cellulose Insulation
8/94
136Contractors' Tips for Spray Cellulose
8/89
140Cool Roofs for Hot Climates
6/03
142The Last Word (We Hope) on Vapor Barriers
8/93
144Practical Details for Energy Efficiency
2/01
144Best Practice Energy Upgrades
3/00
144Fixing the Holes where the Air Gets In
1/04
144Building Airtight Homes
2/02
144Air Sealing the Story-and-a-Half
8/95
148Choosing Energy-Efficient Windows
1/99
148Choosing Vinyl Windows
8/02
150Trouble-Free Forced-Air Heat
12/98
152Trouble-Free Forced-Air Heat
12/98
154Zoning Forced-Air Heating Systems
2/99
158Duct Design Basics
12/95
158Desiging & Testing Forced-Air Systems
8/01
162Installing Direct-Vent Space Heaters
2/00
164Air Conditioning for Humid Climates
10/04
164Sizing Air Conditioners
8/96
166Guide to High-Performance Hydronics
8/90
168Hydronic Baseboard Basics
4/99
170Piping Layouts for Hydronic Heat
3/95
172Radiant Slab Techniques
8/92
172Radiant Slab on a Tight Budget
7/95
176Hardwood Flooring Over Radiant Heat
9/98
176Hydronic Radiant Heat for Wood-Framed Floors
8/93
180Installing a Radiant Wall
12/99
180Radiant Walls and Ceilings for the Bath
9/97
186Venting Gas Appliances
2/03
190Make Up Air for Combusion Equipment
12/99
196Choosing a Whole-House Ventilation System
9/00
198Heat-Recovery Ventilators
3/94
198Installing a Heat Recovery Ventilator
1/02
200Simple Ventilation for Tight Houses
5/91
200Simple Whole-House Ventilation
8/95
200Adding Ventilation to Forced-Air Heat
5/95
204Quiet Bathroom Fans
6/96
206Clearing the Kitchen air
8/91
206Pop-Up Down-Draft Vents
6/93
Chapter 8
PageArticle Title
Issue Date
220Kitchen Design Basics
11/92
224The 31 Rules of Kitchen Design
9/94
226Roughing-In for Kitchens & Baths
12/93
228Installing Framed Cabinets
1/99
228K&B: Staying on Top of the Kitchen
12/96
234Solid Surface Countertops
5/94
234Working with Thin Solid Surfacing
7/98
234Casting Concrete Countertops
12/00
234Cast-in-Place Concrete Counters
8/04
234Installing Stone Counters
6/95
234K&B: Preventing Cracks in Solid Surface Countertops
2/01
236Laminate Countertops on Site
10/93
238Thinset Tile Countertops
8/93
238Durable Substrates for Thinset Tile
8/96
238Membranes for Ceramic Tile
1/96
238Grouting Ceramic Tile
6/99
256Installing Jetted Tubs
9/94
294Sturdy Site-Built Stairs
11/95
294Trouble-Free Stairs
4/97
296Foolproof Layout for Winder Stairs
4/05
298Trimming Out Stairs
3/99
298Stair-Building Tools
12/04
