Finding good help has always been tough, and the current boom
economy has made it tougher. I tackled a recent labor problem
by hiring a company to panelize a 2,400-square-foot house. By
shifting the labor burden to the panelizer, I only had to hire
an inexperienced helper and pay for some crane time, rather
than assembling an entire crew. We erected the shell in four
weeks, or about the same amount of time it would have taken an
experienced four-person crew to stick-frame the same
structure.
Planning and Design
I shopped around among several panel manufacturers before
settling on Sprowl Building Components in Searsmont, Me. -- a
relatively small shop that was willing to work with my custom
design, rather than trying to steer me to a preset package. The
company will also modify its framing details to suit customer
preferences, as long as the details conform to code. For
example, double rough window sills could be substituted for
Sprowl's single-sill detail.
Drawing the plans. I hired a residential
designer to draw a set of floor plans and elevations for the 1
1/2-story house, which has a shed dormer on the south and a
gable dormer over the stairway on the north. The first floor
has an open floor plan with a step down to the living room;
bedrooms and two bathrooms are on the second floor.
Unlike some panelizers, Sprowl doesn't preinstall windows. I
planned to use Eagle windows and doors, so the drawings noted
the center-to-center distances between rough openings. Each
opening was identified by a letter, and a separate window
schedule gave rough opening dimensions.
I specified 2x6 exterior and plumbing walls, 2x4 framed
interior walls, and 5-ply fir plywood sheathing, which I prefer
to OSB. The floors and roof were framed with trusses. Sprowl
redrew the plans with their proprietary software (which will
import AutoCad files, if you have your plans on disc), then
printed out about 35 pages that detailed each panel and truss
(see Figure 1).
| Figure 1.The panelizer's schematics
detail each panel (left) and its place in the floorplan
(below). The wall panel drawing labels components and
provides a cut list. Similar information is given for
truss layout and construction. Booklets shipped with
the panels contain the final schematics for all
components as well as bracing patterns for the roof and
floor trusses. |
Proofing makes perfect. Because the panel
manufacturer works out all the details of the framing, you
never have to do a takeoff. But another important
responsibility takes its place: The necessity of going over
each sheet, comparing it to the original plans, and making any
necessary corrections. Once you've signed off on the
manufacturer's plans, any inconsistencies are your problem.
I proofed the plans carefully, but I failed to catch one
minor glitch. The original plans included a step down to the
living room, and this should have been taken into account in
the framing of the exterior walls. Because it wasn't -- and
because I didn't notice the omission in the proofs -- I had to
deal with it on the job site, by stick-framing a low wall to
fill the gap. I'll be more careful next time.
Assembling the House
About two weeks after I signed off on the plans, the panels
and trusses were ready to ship. As luck would have it, the two
flatbed trucks arrived at the site during pouring rain. We
piled everything on the ground and called it a day.
When the weather cleared, we called the crane back to set
the first-floor girder and floor trusses on the foundation,
then stacked the subfloor sheathing on top. (Given better
weather, we could have done this as part of the initial
unloading and saved an hour or two of crane time.)
Wall connections. After spending a couple of
days gluing and screwing down the subfloor, I scheduled an
afternoon session with the crane to set, line, and brace the
first-floor exterior wall panels (see lead
photo at the beginning of this article). The exterior wall
corners were framed with 12-inch-wide "ladders" at the end of
one panel, to which the end stud of the adjoining panel is
toe-nailed.
The next morning, I positioned and nailed the first-floor
interior wall partition, while my helper readied the
second-floor trusses and subflooring to be lifted into place
(Figure 2).
Figure
2. Bundled second-floor trusses are set atop the
first-floor walls. The lumberyard strapped together
several sheets of plywood subfloor before delivering it
to the job site. The 20-foot-high stairwell panels are
visible in the background. |
As with the exterior wall panels, partition walls were
joined at "ladders" built into the framing. This worked very
well and made it easy to align the walls while providing some
flexibility in the floor plan (Figure 3). If it doesn't cause
problems elsewhere, nonbearing partitions can easily be shoved
one way or the other by a few inches to alter the size of a
room or closet.
| Figure
3. Partition-wall intersections are simplified
by the presence of framing "ladders." The end stud of
the adjoining wall is nailed to the ladder, as shown
here, making it easy to adjust the final position of
nonbearing partitions as needed. |
