During a recent remodeling project in Houston, we demolished a structurally defective balcony that had been supporting the corner of a roof. In its place we installed an 18 1/2-foot-long 4x4 steel post that extends from the soffit down to ground level. We created a brick pedestal to cover the lower part of the post , then concealed its upper portion with a 10-foot fiberglass column.While columns can be split on site, most manufacturers will do it for you. Split columns can't be used in load-bearing applications, and some manufacturers caution that they need to be installed as soon as...
