Download PDF version (2510.6k) Log In or Register to view the full article as a PDF document.
Phase 1: Frames and Panels
Launch Slideshow
2. The clamps provide the pressure, while the headless pins keep the panels aligned.
A Contemporary Box Newel Post
Creating the tapered frames and panels
  • Tapered Frames
    1. The tapered center section of the newel is made up of four frame-and-panel assemblies. I transferred the dimensions and angles for the stiles and rails from my full-scale drawing, cut them to width and length from 34-inch poplar, and joined them together with pocket screws and glue.
    http://www.jlconline.com/Images/tmp7338%2Etmp_tcm96-1495180.jpg
    true
    600
    The tapered center section of the newel is made up of four frame-and-panel assemblies. I transferred the dimensions and angles for the stiles and rails from my full-scale drawing, cut them to width and length from 3/4-inch poplar, and joined them together with pocket screws and glue.
  • Tapered Frames
    2. I then cut a 38-inch rabbet around the inside of each frame with a router to accommodate the plywood panels, which I would make from readily available 34-inch birch plywood.
    http://www.jlconline.com/Images/tmp7339%2Etmp_tcm96-1495183.jpg
    true
    600
    I then cut a 3/8-inch rabbet around the inside of each frame with a router to accommodate the plywood panels, which I would make from readily available 3/4-inch birch plywood.
  • Panel Cuts
    1. To safely cut the tapered 34-inch plywood panels, I made a plywood sled for the table saw and used the drop from the first angled cut as a spacer for cutting the remaining edges.
    http://www.jlconline.com/Images/tmp733A%2Etmp_tcm96-1495185.jpg
    true
    600
    To safely cut the tapered 3/4-inch plywood panels, I made a plywood sled for the table saw and used the drop from the first angled cut as a spacer for cutting the remaining edges.
  • Panel Cuts
    2. Instead of squaring the corners of my rabbet in the back of the frame with a chisel, I clipped the corners of each plywood panel with the miter saw.
    http://www.jlconline.com/Images/tmp733B%2Etmp_tcm96-1495188.jpg
    true
    600
  • Panel Cuts
    3. I applied yellow glue to the rabbets, dropped the panels in place, and secured them with headless pins while the glue dried.
    http://www.jlconline.com/Images/tmp733C%2Etmp_tcm96-1495190.jpg
    true
    600
  • Panel Cuts
    4. In preparation for assembly, I ripped 34 inch from the 178-inch-wide stiles of two of the frames. I also cut a 15-degree angle on the bottom rail of each frame, using the table-saw miter gauge and the wedge-shaped spacer to hold the frame square to the blade.
    http://www.jlconline.com/Images/tmp733D%2Etmp_tcm96-1495193.jpg
    true
    600
    In preparation for assembly, I ripped 3/4 inch from the 1-7/8-inch-wide stiles of two of the frames. I also cut a 15-degree angle on the bottom rail of each frame, using the table-saw miter gauge and the wedge-shaped spacer to hold the frame square to the blade.
  • Frame and Panel Assembly
    1. I glued the four frames together, pinning them to each other with my 23-gauge headless nailer to hold the assembly in place while I set up my clamps.
    http://www.jlconline.com/Images/tmp7348%2Etmp_tcm96-1495238.jpg
    true
    600
    http://www.jlconline.com/Images/tmp7349%2Etmp_tcm96-1495242.jpg
    true
    600
    3. Setting the two wider frames slightly proud of the two narrower frames made it easier to flush-trim the joints with a router after the glue dried; this resulted in better-looking joints. I cleaned up the 26-inch-high assembly with a random-orbit sander and 120-grit paper.
    http://www.jlconline.com/Images/tmp734A%2Etmp_tcm96-1495246.jpg
    true
    600
    4. While the tapered glue-up was drying, I made the four rectangular panels for the 9-inch-high upper assembly in the same way.
    http://www.jlconline.com/Images/tmp734B%2Etmp_tcm96-1495250.jpg
    true
    600
    5. I again used headless pins to keep the panels aligned as I clamped them together.
    http://www.jlconline.com/Images/tmp734C%2Etmp_tcm96-1495254.jpg
    true
    600
  • Installation
    4. Later, after I was finished installing the treads, handrail, and balusters for the landing, my painter added the finishing touches.
    http://www.jlconline.com/Images/tmp735B%2Etmp_tcm96-1495304.jpg
    true
    600
In some ways making the frames and panels, and assembling the four sides of the box newel post is the craftiest part of the project. Because the body of the box is tapered, you might be tempted to cut compound miters along the mating outer stiles of the panel frames. I devised a method to avoid making those tricky cuts. In the accompanying slide show you'll see how I:
  • Joined the frame members with pocket screws
  • Rabbetted the frames to accept the panels with a router bit
  • Cut the tapered panels on a table saw using a "sled" to maintain consistent angles
  • Joined the panels to the frames
  • Assembled the frame-and-panel sections
  • Trimmed the mating panel rails with a flush-cutting router bit for perfect corners
