Download PDF version (2510.6k) Log In or Register to view the full article as a PDF document.
Phase 4: Installing the Newel Post
Launch Slideshow
2. After a dry fit, I covered the blocking with plenty of construction adhesive and slid the post into place, shimming it plumb and then fastening it to the blocking with long structural screws driven in from three sides.
A Contemporary Box Newel Post
Installing the post
Installing the post
  • Installation
    1. Before setting the post, I marked the location of the center of the handrail on the landing, then lined up the center of the post with these marks. This helped me locate the blocking needed on the floor and riser for mounting the post.
    http://www.jlconline.com/Images/tmp7358%2Etmp_tcm96-1495301.jpg
    true
    600
  • Installation
    http://www.jlconline.com/Images/tmp7359%2Etmp_tcm96-1495302.jpg
    true
    600
  • Installation
    3. Finally, I finished the post with a 912-inch-wide plywood base, mitering the corners and adding a chamfered cap to hide the joint.
    http://www.jlconline.com/Images/tmp735A%2Etmp_tcm96-1495303.jpg
    true
    600
    Finally, I finished the post with a 9-1/2-inch-wide plywood base, mitering the corners and adding a chamfered cap to hide the joint.
  • Installation
    4. Later, after I was finished installing the treads, handrail, and balusters for the landing, my painter added the finishing touches.
    http://www.jlconline.com/Images/tmp735B%2Etmp_tcm96-1495304.jpg
    true
    600
The final phase involved fastening the newel post in place and adding the decorative frame-and-panel base to conceal the structural connections. In the accompanying slideshow you'll see how I:
  • Set blocking and cleats on the floor and first stair riser to provide adequate structural support for fastening the newel post in place
  • Fastened the base of the newel so that it won't budge
  • Finished the base of the newel post with panels and chamfered trim
Gary Striegler is a builder in Springdale, Ark.
