Air-Sealing Options: Better
Better air sealing (tightening to around 1.5 ACH50) requires a peel-and-stick or fluid-applied WRB, or a taped sheathing system, such as ZipWall. Here, the author has installed Corsella Dorkin’s Delta Vent SA .
With a perm rating of 50 it works in all climate zones. Sheathing must be primed before applying the WRB.
Windows need to be sealed with a low-expanding foam from the inside and taped on the outside.
Similarly, all through-wall penetrations must be foamed from the inside and taped outside.
Bottom wall plates must be caulked or taped inside, and sealed with flexible flashing outside.
Join the Discussion
