Getting Oil Results With Waterborne Finishes
The author sands new trimwork with 120-grit paper before filling holes and priming. Good dust collection streamlines the process.
After patching nail holes and dings and sanding again, the author primes the trim.
A selection of fast-drying, sandable, waterborne primers.
Waterborne primers raise the grain, so once the primer has dried, he sands it with 150- to 180-grit paper to smooth out the surface. and prepare it for top-coating.
For production spraying of heavy-bodied waterborne trim paints, the author uses Graco’s Finish Pro 395 (A) air-assisted airless sprayer
The G40 gun that comes with the Graco rig is HVLP-rated.
It minimizes overspray and gives good control over the fan pattern at the tip of the gun.
Graco’s ProShot 18-volt cordless sprayer works well with waterborne primers and paints and is easy to clean afterward. It holds just a quart, though, so the author reserves it for smaller jobs.
Whether brushing, spraying, or rolling, the author strains all waterbornes — even freshly opened gallons — before using them.
Waterborne trim paints tack up in less than an hour, reducing the risk of dust contamination.
When properly applied, they produce a smooth cabinet-grade finish ...
... with a satin sheen.
Join the Discussion
