Installing Horizontal Siding
Start by making a simple cutting table—usually a 2x4 frame with a fence and enough space directly behind the cutting area stack the siding.
Pieces can be gang cut to the same length with a circular saw.
Mark the location of every framing member on the WRB using a permanent marker.
Install the starter strip.
For a fixed reveal, use siding gauges to set the course spacing.
Flash butt joints with a card made from aluminum coilstock.
Although most siding can be notched on the ground, fiber-cement should be notched by the installer to minimize breakage during handling.
Install starter strips to support the siding above windows.
Aluminum coil stock painted to match the siding is a good flashing.
Caulk vertical seams, aiming for a bead that has a slightly concave shape when viewed in cross section.
Join the Discussion
