Lead-Safe Paint Removal, Images 9-15
The Metabo tool is easy to control and works deep into the corners.
Adjusting the cutting depth is done with a T-handle Allen wrench.
When it's outfitted with fresh 36-grit sandpaper, the Festool is fast and smooth.
Effective dust collection depends on correctly positioning a moveable brush by rotating an auxiliary handle; turning the handle clockwise rotates the brush counterclockwise.
A quick-release lever makes it easy to remove and adjust the Festool's extractor hood, but an inadvertent bump can knock everything out of alignment.
The Speedheater has a multisided profile scraper that allows it to remove paint from moldings as well as flat stock.
Join the Discussion
