Replacing a Bulkhead Door, Images 10-17
Bottom: I ripped the bottom pieces to match the angle of the sides, again using two pieces to get a wider frame.
Bottom: I glued and screwed them together, as I did with the sides.
Bottom: I cut the laminated piece to length.
Bottom: I applied Woodlife Coppercoat preservative to all the pieces to help prevent the wood from rotting, and the frame was ready to assemble.
Assembly: I predrilled holes for long timber screws, then applied adhesive.
Assembly: I screwed the tapered sides to the bottom piece.
Assembly: A cleat tacked across the sides kept the frame from racking as I positioned it.
Assembly: After shimming the bottom with strips of PVC so that it rested flat, I predrilled holes through the wood into the concrete and secured the frame with Tapcon screws. Given the poor condition of the concrete, this seemed safer than using powder-actuated fasteners.
Join the Discussion
