Restoring a Standing Seam Roof, Images 1-9
The original painted roof
The roof was pressure-washed, then allowed to dry.
The contrasting green primer coat that came next revealed areas that needed further attention with a wire brush.
Painted sheet aluminum was used to patch holes where vents had been removed.
A white bedding coat and polyester fabric followed the green primer.
e standing seams were treated first, with strips of fabric pressed over the raised profiles into the thick compound.
The field of the roof was then covered.
The roof was ready for the finish coats.
Join the Discussion
