Warm House for a Cold, Cold Winter
Mike Trolle’s Passive House was built on the remnants of a summer cottage in a Connecticut Lake community. The only parts that were salvaged for the new home were the original CMU foundation, first-floor joists, and subflooring.
The original subfloor with its new, taped layer of plywood can be seen in the center of the photo. On the right, a 6-inch layer of stone dust—for thermal mass—covers 12 inches of foam.
Drains that are under the crushed-stone base for the patio at the back of the house remove water that seeps down the sloped lot. Gutter leaders from the long south-facing roof will also tie into the same system.
Plywood sheathing joints were taped before horizontal 2x3s and 1/2-inch plywood strips were added. HRV exhaust is seen between dormer windows.
2x3s and1/2-inch plywood strips were lagged to the studs through the taped plywood sheathing. Two-inch-thick polyisocyanurate-foam sheets were installed between the 2x3 plywood nailers.
A second layer of foam was added over the first and held in place by lag bolts through the vertical 1x3s, which also create a rain screen for the Hardiplank siding.
Triple-pane Klearwall windows, which are made in Ireland, are used throughout the house.
Hardiplank siding and Boral TruExterior trim cover the exterior of the Passive House.
The Mitsubishi minisplit heat-pump system worked flawlessly throughout the brutal winter.
Join the Discussion
