Make Your Own Flooring. Carbide Wood Flooring Router Bit Sets let you mill tongue-and-groove flooring from solid or engineered wood. Each includes one bit for the groove and one for the tongue; the latter also puts a nail slot in the tongue to prevent the nail head from interfering with the joint. The bits are for use in table-mounted routers only. A set costs $114 or $120, depending on the board thickness you're working with. Amana Tool, 800/ 445-0077. www.amanatool.com
Go to JLC
