Cutting, aligning, and gluing square-edged post wraps can be a pain, and even interlocking products may require two sets of hands to install. KleerWrap eliminates a lot of the hassle and can be put in place by a single worker. It consists of a pre-assembled wrap with one loose panel; you simply remove the loose panel and then glue it back in place once the wrap is on the post. The interlocking joint makes the panel self-aligning. A 4-by-4-by-8-foot wrap costs about $75, an 8-by-8-by-10-footer around $165.
Kleer Lumber, 866/553-3770,
