Use one pump start-to-finish for stucco and EIFS applications with Graco's new ToughTek S340e Portable Stucco Pump. The newest addition to the ToughTek line has a 20-gallon hopper and uses piston pump technology to deliver abrasive materials with a smooth, steady flow, as well as the ability to use long hose lengths, making it suitable for any size project. For EIFS applications, the S340e handles air/water-resistive barrier materials, EIFS base coats, and finish coats. For stucco, the unit handles scratch coats, brown coats, and finish coats. The unit's compact design and small footprint improve access for spraying in tight areas, and variable speed controls to dial-in the exact flow rate needed. The pump plugs into a standard 120V wall outlet or may be used with a 5.5 kW generator.
