Slicker HP Housewrap is the latest in Benjamin Obdyke's portfolio of roof and wall products. The material combines a water-resistive barrier and rainscreen into one solution that works for both residential and light commercial applications. Ideal for use with wood, fiber cement, stone veneer, and stucco cladding, Slicker HP makes installing a rainscreen easier by incorporating vertical channels to help direct builk water out of the exterior wall via a 1/4-inch drainage space. The rainscreen also can be removed without compromising the housewrap element of the material. Featuring a 20-year system warranty when installed with the maker's flashing accessories, Slicker HP costs 90 to 95 cents per square foot, depending on region. benjaminobdyke.com
