Designed specifically for installing deck clips, the SuperDrive 75G5 fastening tool from Grabber Construction Products effectively automates clip installation along joists. Available in a kit that includes the SuperDrive 75G5, a Rocker 4,000 rpm screw gun, and feed track, the tool helps drive screws as the ideal angle and depth every time, while offering a compact and lightweight design. Installers can also opt for the SuperDrive extension piece to allow for use from a standing position, and can configure the tool for top fastening. Each collated strip holds 50 screws. Priced at $380. grabberman.com
