Flexible Corner Tape. If you'd like to simplify the process of finishing drywall corners, take a look at FibaTape Composite Drywall Corner Tape. Unspooled, the tape becomes rigid; you cut and fold it to length, then install it over corners using standard joint compound. It's made from a perforated, fiber-coated PVC that the maker says promotes fast drying, so it can be second-coated immediately. A 50-foot roll costs $18. Saint-Gobain Technical Fabrics, 800/762-6694, fibatape.com
