Bilco
The StakWel Egress Window Well system uses modular units (about $100 each) that stack together to accommodate virtually any foundation depth. Redesigned to work with utility or egress window openings up to 54 inches wide, the system is constructed of corrosion-resistant high-density polyethylene that is impervious to moisture conditions and won’t rust, rot, or discolor, the maker says. bilco.com
