On most kitchen cabinet installations, the mounting screws are inconspicuous and the client never notices them. But for display cases behind glass doors, I use a couple of tools from FastCap (888/443-3784, www.fastcap.com) to make screw heads disappear.
The FlushMount Drillbit — a carbide bit with an adjustable depth stop — drills recessed pilot holes sized for FastCap's PowerHead screws, which have large washerlike heads that won't pull through. If the stop on the bit is correctly set, the screw head ends up just below the surface. Apply a FastCap peel-and-stick cap and it's nearly impossible...
