Inconspicuous Doorstop. The DoorSaver II is a replacement hinge pin with an adjustable mechanism that uses the exposed portion of the hinge leaf (rather than the soft face of the door or casing) as a stop. The desired range of motion can be adjusted in increments of 11 degrees. The maker says these devices will not mar the surface of a door - and the company backs up that assurance with a promise to replace the door if there is any damage. The DoorSaver II comes in six decorative finishes and sells online for $5. Perfect Products, 877/366-7728, doorsaver.com.
