When newly installed flooring needs to be protected, Surface Shield’s Builder Board Breathable Tape lets crews cover the material and allow it to cure without risking damaging cure lines. The combination of Builder Board protective boards and breathable tape creates a jobsite solution that allows vapor and moisture to escape. Additionally, the tape is formulated with a higher adhesion level than similar products on the market without affecting the breathability. Available in 3-inch by 36-yard rolls for about $15 each, or check with your distributor for specific pricing. surfaceshields.com
