Dampner Disengaged A 001
Tom Balla Dampner Disengaged A 001
As sliding and pocket doors continue to gain popularity, Johnson Hardware's new soft-close hardware will keep those stylish design additions from being banged up. The hardware works like a cabinet door closer with pocket, sliding, and wall-mounted doors, allowing doors to open effortlessly but close quietly and securely without slamming. In addition to reducing noise, the feature also prevents pinched fingers and helps ensure privacy from fully closed doors. Suitable for new or retrofit installations, soft close sliding door hardware installs quickly on a wide range of the maker's door systems. Priced at $60 for single-directional configuration or $87 for bi-directional, each set includes a soft close dampener, two door hanger plates, an actuator, and a ball-bearing door hanger. johnsonhardware.com
