Builders can create flush baseboards for drywall abutting wood or other materials with the Architectural L Bead from Trim-Tex. The L bead is installed by applying an adhesive coating to the bead, attaching it to drywall, and then stapling every 4 to 6 inches with 1/2-inch staples before installing the baseboard. The clean, sharp lines add a modern element to spaces while minimizing the maintenance costs that often arise from debris settling on traditional baseboards. Pricing ranges from $0.14-$0.18 per foot. trim-tex.com
