Save time and money with Trim-Tex’s newly designed 560 Sanding Pads, available in five grits from extra fine to extra coarse and in corresponding colors for easy identification. With a 60% larger sanding surface than other products, the product’s abrasive grit is bonded directly to the foam pad, so there is no paper to scuff up walls when sanding inside corners. Like the previous version of the product, the 560 Sanding Pads also feature the maker’s quick-change system, which allows users to easily switch sanding pads when using them in conjunction with the Trim-Tex 540 Pro Sander. Check with your dealer for
quantities and pricing. trim-tex.com
