Easy Cure for Clogs. Instead of plunging, snaking, or pouring harsh chemicals down a stopped-up drain, how about just turning a dial? The No Clog Drain replaces a conventional P-trap with a device that generates turbulence to prevent buildup of debris. If a stoppage occurs anyway, an integral wiper operated by a dial sweeps away the blockage. This setup also makes it easy to retrieve lost valuables, the maker says. The drain costs about $20. PF Waterworks, 877/265-9777, pfwaterworks.com.
