Available from Thomas & Betts, the Red Dot Deck Grommet Pro Floor Box keeps outdoor-rated outlets out of sight unless and until they’re needed. The unit is hardwired to add power outlet service to any part of a residential or light commercial raised deck. When the outlet is not in use, the Deck Grommet Pro stays concealed beneath the deck board, with only it’s non-metallic cover showing.
Ideal for outdoor living and hospitality areas, the unit provides easy access for small appliances, lighting, and water feature pumps. A duplex adapter plate is included for use with conventional TR/WR duplex receptacles. The Deck Grommet Pro is UL-approved in the U.S. and Canada, and complies with National Electric Code for unattended in-use plugs in wet locations, required “extra duty” outlet box hoods, and NEMA 3R enclosure ratings for protection against falling rain, sleet, snow, and ice formation. The Red Dot Deck Grommet Pro Floor Box retails for about $40. tnb.com.
