Scott Rosenberg
Get the benefits of arc prevention and grounding together in Leviton's SmartLockPro Dual Function AFCI/GFCI Receptacle. The Arc Fault Circuit Interrupter and Ground Fault Circuit Interrupter in one is compliant with the National Electric Code for use in new-construction residential kitchens and laundry areas, as well as for modifications, extensions, or replacement of receptacles. The device's face features "test" and "reset" buttons, as well as a status indicator light for easy indication of the receptacle's status of normal, mis-wiring, or AFCI or GFCI trip. For an added safeguard, the SmartLockPro Dual Function receptacle also features the maker's patented reset lockout, which prevents the device from being reset if it's not functioning properly. Priced around $30. leviton.com/dfci
