Nora Lighting has added an adjustable LED downlight with a 5-inch aperture to its Diamond II Retrofit Series of recessed LED fixtures. The luminaire offers a 10.55W LED module with realistic color rendition. An adjustable gimbal rotates 356 degrees and adjusts from 0 to 40 degrees, making the fixture ideal for wall-washing effects as well as accent lighting in sloped ceiling applications. Diamond Series retrofit units work with a variety of dimmers and are rated for use in damp locations. Models are available in a wide range of finishes and three trims packages, including surface adjustable, regressed baffle, and regressed reflector. noralighting.com
