No Sweat. Installing supply-line shutoffs just got easier, thanks to Watts' new KwikStop Water Supply Stops. Available in straight and angled styles, the NSF-approved quarter-turn valves simply push on to 1/2-inch copper, CPVC, and PEX tubing. According to the maker, they can be removed and reused if necessary. List price is $6.15 each. Watts, 978/688-1811, www.watts.com
Jacket Required? Whether embedded in a slab or running through accessible space, water lines can be challenging to fix or replace. Pre-Sleeved 1/2-inch Aquapex Tubing is designed with its own color-coded high-density polyethylene sleeve, which makes repairs and replacements a lot less difficult. This product is ideal for water lines buried in...
