Carpenters and deck-builders who use hollow composite decking such as GeoDeck often saw conventional deck boards into their own unique profiles for trim details. Now GeoDeck offers a pair of new ready-made profiles designed to eliminate much of the custom cutting. The Perimeter Strip (top) is commonly installed like a skirtboard to hide the decking's open ends. The Feature Strip (center) is a T-shaped profile used for hiding a long row of butt joints, as in the center of a chevron pattern; it allows the decking to move with changes in temperature. (Be aware, though, that the installed strip will be slightly higher than the surrounding boards.) The Feature Strip costs about the same as the conventional 5/4x6 GeoDeck decking profile; the Perimeter Strip costs about 10 percent more. Kandant Composites, 877/804-0137, www.geodeck.com
Replacement sash and balances are great for upgrading windows with sound frames and trim, but sometimes you have to replace the whole unit. Crestline's Replacement Window with Applied Brickmould can be ordered in just about any size, which isn't unusual for such products; more exceptional is that the unit includes the window frame and exterior...
