Perching a solid-core door on your foot while you sneak in a hinge pin is a good way to mash your toes if not to hang a door. Enter the Doorminator, a heavy-duty rolling cart that makes supporting and hanging a heavy door by yourself as easy as dropping in the pins. The cart lifts and positions the door while spring-loaded hooks hold it steady. A 300-pound, 48-inch-wide capacity should handle just about anything you're likely to install, and forward, back, and sideways adjustments make both hanging and removal easy and safe. The Doorminator weighs approximately 65 pounds and has a swiveling back leg to negotiate tight spaces and narrow openings. It costs about $400 (plus shipping).
Contact: Telpro Inc., Grand Forks, N.D.; 800/448-0822, http://www.telprodirect.com.
