A Leg Up. Setting up scaffolding on uneven ground can be nearly impossible, but ReechCraft's Bronco All-Terrain Scaffolding System is made for the challenge. Each plank support is a tripod for extra stability, with legs that extend from 31 to 55 inches. (Longer leg extensions are available for fitting extreme angles and contours.) According to ReechCraft, the product can be used on slopes as steep as 8/12. Each powder-coated support weighs 23 pounds and folds flat for easy transport and storage. A set of two supports costs $349. ReechCraft, 888/600-6160. www.reechcraft.com
Go to JLC
