USP’s new two-part anchoring epoxies include targeted formulas for nearly every jobsite condition. Designed for embedding rebar or threaded rod into masonry, the line includes formulas for concrete foundations in earthquake and hurricane-prone regions (where the connection might need to withstand high tension and shear loads), for attaching anchor bolts in brick or concrete block, and for general-purpose work. There are even fast-cure and cold-weather formulations, the latter of which will flow in temperatures as low as 34 degrees F. Prices range from $14 to $24. USP Structural Connectors, 800.328.5934, uspconnectors.com
