Are you a subscriber but don’t have an online account?
Register for full online access.
Foundations & Framing
  • Image
    Formwork for Carpenters
    Developed by a Utah contractor, the Spider Tie system is for builders and remodelers who want to do their own formwork
  • Image
    Ultimate Framer
    With the Chappell Master Framer, you can calculate cuts for complex roof frames
  • Image
    Warmer, Drier Basements
    Superior Wallsí XiPlus foundation panels have an insulation value of R-21
  • Image
    Repairable Moment Frame
    The Strong Frame SMF withstands earthquakes better than most special moment frames, says Simpson
  • Image
    Heavy-Duty Truss Hangers
    Simpson's new truss hangers are said to have some of the highest loads in the industry
  • Image
    No More Sonotubes
    Reinforced-concrete Perma-Columns keep wood posts away from ground moisture
  • Image
    Crawlspace Cover
    The 8 Mil Floor Liner is durable and easy to install, says the maker
  • Image
    Shrink-Resistant Floor Tie Screw
    The SDWF structural wood screw is designed to help compensate for a structure's shrinkage over time
  • Image
    Flex-Drain Expandable Drain Pipe
    Flex-Drain holds its shape like a giant bendy straw, eliminating the need to cut pipes and insert fittings
  • Image
    Guardrail System for Fall Protection
    The Horizontal Under-Eave Guardrail System is an easy-on, easy-off rooftop railing for use with trusses.
  • Coated I-Joists
    PKI Engineered I-Joists get their distinctive pink color from a nontoxic coating that the maker says resists fire, repels water, and prevents mold growth.
  • Image
    Product: Altruwood Hand-Hewn Beams
    Timber from dismantled barns in New England and the Midwest.
  • No-Leak Membrane for Concrete Footings
    The Delta Footing Barrier is a three-ply impermeable membrane that goes on top of freshly poured footings before the foundation is built.
  • Post Wrap
    Versatex has added 4-by-6-inch and 8-by-8-inch sizes to its precut Versawrap PVC column cladding for rough-sawn wood posts (existing sizes are 4 by 4 inches and 6 by 6 inches.)
  • Image
    Burn Notice: LP FlameBlock Fire-Rated OSB
    Meet code in row houses, multifamily dwellings, and other buildings using FlameBlock fire-rated OSB for structural strength and fire protection in one.
  • Framing Fixer
    The next time the plumber goes berserk with a Sawzall, it might not take so long to repair the damage.
  • Faster Through-Bolt
    If you're still using a socket wrench to fasten posts or beams, you might want to check out the ThruLok Screw Bolt Fastening System.
  • Insulated Framing
    Weyerhaeuser has introduced a line of framing material designed to reduce thermal bridging.
  • Prefab Arches
    Want to avoid the hassle of fabricating curved framing on site? Consider sending the plans to Custom-Arch and letting someone else do the work.
  • Adjustable Level
    The Plumb Perfect Level features end gauges that can be dialed in or out to compensate for imperfect framing (or to establish a slope).
