A.Martin Holladay responds: First, connect any two points of the arc with a straight line. Find the center of that line and draw a perpendicular line through the center point. Then do the same thing again elsewhere on the arc — connect two points with a straight line and draw a perpendicular line through the center of that line.
The point where the two perpendicular lines cross is the center of the circle.
