by Steve Easley
These days, it's not an exaggeration to say that almost all homeowners expect their homes to be durable, energy efficient, safe, and comfortable. But this is especially true in coastal markets that cater to high-end clients who demand supreme quality and impeccable performance from their homes. Even in today's markets, which are euphemistically described as "relaxing," there seems to be no shortage of wealthy home buyers snapping up second-home properties along the coveted coast. If you build in this market, it's this kind of discriminating home buyer who will most expect you to get things right.
In more than 25 years of consulting with builders on ways to reduce callbacks, I've spent most of my time solving problems related to heat and moisture transfer through buildings, because this is often where builders — even very good builders who deliver well-appointed homes to the coastal elite — get things wrong. Most of the serious (read "expensive") performance failures are moisture related, and a good number of these are closely tied to the thermal performance of the home. Yet I am surprised how often the insulation is installed without much thought or understanding about how it works. Consequently, very little attention gets paid to the details that really matter. Typically, fiberglass — selected as the least expensive option up front — is jammed in the walls and stuffed around electrical wires, plumbing pipes, and HVAC ducts, then covered up as soon as the municipality allows. The result is gaps, compression, and hollow voids that compromise occupant comfort and increase the building's energy loads. A sloppy insulation job can also lead to moisture problems by creating thermal conditions in walls and ceilings that promote condensation, wetting, mold growth, and rot.
Batt insulation works best when it is fully lofted, not jammed into the tight spaces (above). Compression of the batt reduces the number of air pockets that provide the material's insulation value. It also leaves a hollow between the insulation and the drywall, creating areas where air can circulate. These voids can siphon off energy and may create conditions for condensation and moisture problems.
Bright Star
The updated Energy Star label for homes provides a quality standard that can guide builders away from these problems. New program requirements have raised the level of quality in the program, making it a label that savvy home buyers will more likely be looking for. As of January 1, 2007, a home that qualifies for an Energy Star label must pass a "thermal bypass inspection": a rigorous assessment of a home's air barrier. The bypass inspection requires builders to follow the EPA's Thermal Bypass Inspection Checklist — a 25-point list of details aimed at stopping the movement of heat around or through the insulation. Thermal bypasses — the defects that most commonly reduce the energy performance and comfort of homes — typically result from missing or compressed insulation, missing air barriers, and gaps between the air barrier and the insulation.
The Energy Star Thermal Bypass Inspection Checklist must be completed by a certified home energy rater. However, in order for a home to qualify for the Energy Star label, up to six items may be verified by the builder to minimize required field trips by the rater.
In my opinion, this checklist is one of the best guidelines to come out of the EPA's Energy Star program, and I think it substantially raises the bar for thermal and moisture performance of building envelopes. Of particular value to builders, the 86-page Thermal Bypass Checklist Guide (available free online at www.energystar.gov; search "Thermal Bypass Guide") provides a very practical and comprehensive look at reducing air infiltration. It should be required reading for anyone who's serious about building a quality home in any climate, but especially in demanding coastal climes.
Living Spaces Over Garages
Living spaces over garages create conditions that demand careful attention to insulating the floor. Yet it is difficult to support the insulation in this cavity, and oftentimes the insulation falls onto the garage ceiling. This separation between the insulation and the living space floor creates a thermal bypass that compromises the value of the insulation. Air easily infiltrates in at the band-joist area over the top of the insulation, which scavenges away heat. This often freezes plumbing pipes, creates cold floors, and can lead to major mold and water damage. Builders often try to solve the problem by supplying forced-air heat near the plumbing, but this only succeeds in pressurizing the space with warm, humid air. As this air exfiltrates through the exterior cracks, it can condense and lead to even worse moisture and mold problems at the band-joist areas.
The issues are easily solved with ccSPF, which sticks to the bottom of the subfloor so insulation and air barrier are always in contact. The foam also stops air infiltration. It is a good idea to wrap any plumbing with a thin layer of fiberglass insulation before spraying foam over it to make servicing the plumbing easier.
An Insulation for All Reasons
I've included in this article a short catalog of some of the problem areas addressed on the Thermal Bypass Inspection Checklist that I find are frequently missed.
What stands out about all of these problem points is that they can be difficult to get right with inexpensive fiberglass insulation unless a builder is working with an experienced and service-minded insulation crew. However, these problems are easily avoided when using closed-cell spray foam (ccSPF) insulation. This alone provides a strong argument for always using ccSPF, but it's certainly not the only reason.
There are many reasons why ccSPF makes particularly good sense in a coastal home:
• It has a high R-value of 6.5 to 7 per inch.
• It absorbs a negligible amount of water. It can even be used as an effective secondary rain barrier and is the only FEMA-approved insulation for flood-resistant construction.
• It does a good job of controlling diffusion.
• It has good air barrier qualities to reduce airflow into and out of wall cavities.
• It expands to fill voids in hard-to-
insulate areas.
• It provides some structural integrity to the frame (see "The Structural Properties of Foam," page 26).
Steve Easley is principal of Steve Easley Associates, a company based in Danville, Calif., that provides building-science training and quality assurance for builders nationwide. All photos by the author.
Attic Knee Walls
These are areas where the insulation on the back side of unsheathed walls is exposed to outdoor temperatures and airflow. They are often adjacent to ventilated attic areas. The Energy Star Thermal Bypass Inspection Checklist requires that an air barrier be placed on all sides of the insulation. This means that the back sides of knee walls need to be sheathed and sealed. Thin-profile cardboard sheathing with ccSPF works well here. Since ccSPF is air impermeable, the insulation does not have to fill the entire cavity, and it meets the air barrier requirement. Some codes require R-19 insulation, which is difficult to do in a 3 1/2-inch space with batt insulation, but 2 inches of ccSPF provides about R-19.5.
Sloping Roof Areas
The sloping areas in a cathedral ceiling can be the sites for significant thermal bypasses. These areas are not only difficult to insulate but are difficult to ventilate. Yet ccSPF solves both problems. Placing ccSPF directly on the underside of the roof deck also creates a secondary rain barrier, and because of ccSPF's high R-value and low permeability, moisture is not likely to condense on its surface, eliminating the need for cavity ventilation.
Band-Joist Areas
The band-joist area is typically a major site for air infiltration. These areas are usually very poorly insulated, causing one of the most significant thermal bypass areas. If the home is under a positive pressure (air pushing out from inside) in a heating climate, the air is likely to be at a high humidity level. This can cause frost, and eventually mold, to build up on the back side of the band joist. In a cooling climate that is under negative pressure (air pulled inward — a condition that's commonly caused by leaky HVAC ducts), this can pull hot, humid air from outside, where it is likely to condense and lead to mold problems. The sealing properties of ccSPF will reduce these air-infiltration and energy-loss problems in this troublesome area.
Attic and Crawlspace Bypasses
Attic and crawlspace bypasses are penetrations into the living spaces. Pipes, ducts, flues, and electric wires are the most common reason for these penetrations, and the best way to seal them is often (but not always) with ccSPF. Because ccSPF expands and seals, it does an excellent job of filling voids that allow conditioned air to escape. However, ccSPF should not be used to seal around high-temperature areas such as combustion appliance flues.
