Launch Slideshow
Making and Installing Sound-Absorbing Panels
  • http://www.jlconline.com/Images/834243539_soundproof-panel-1_tcm96-2162251.jpg
    true
    600
    A crew member applies glue to the edge of a “REVRB” sound-absorbing panel frame in New England Soundproofing’s Waltham, Mass., cabinet shop.
  • http://www.jlconline.com/Images/1932467402_soundproof-panel-2_tcm96-2162250.jpg
    true
    600
    Adding a plywood back to the sound-absorbing panel frame.
  • http://www.jlconline.com/Images/1759041288_soundproof-panel-3_tcm96-2162249.jpg
    true
    600
    Stapling the plywood back to the panel frame.
  • http://www.jlconline.com/Images/716872437_soundproof-panel-4_tcm96-2162248.jpg
    true
    600
    Spraying the frame’s plywood back with adhesive.
  • http://www.jlconline.com/Images/618321402_soundproof-panel-5_tcm96-2162247.jpg
    true
    600
    Installing sound-absorbing rock wool fiber insulation into the panel. The insulation comes in one-inch, two-inch, and three-inch thicknesses. Thicker insulation is better at absorbing low frequencies of sound, while thinner insulation is more effective with higher frequencies. Drago typically uses a two-inch thickness to optimize sound absorption across the broadest frequency range.
  • http://www.jlconline.com/Images/25739251_soundproof-panel-6_tcm96-2162246.jpg
    true
    600
    Slicing the sound-absorbing insulation to fit with a knife.
  • http://www.jlconline.com/Images/1041997102_soundproof-panel-7_tcm96-2162245.jpg
    true
    600
    Fitting the screen-printed cloth covering over the “REVRB” insulated panel. Cloth used for this purpose must be rated to allow the passage of sound waves, so that the sound energy can penetrate the panel surface and be absorbed by the rock wool insulation interior.
  • http://www.jlconline.com/Images/1870983199_soundproof-panel-8_tcm96-2162244.jpg
    true
    600
    A crew member wraps the screen-printed panel cover around the back of the panel and staples it to the panel frame and back. Steve Drago, son of company founder Joseph Drago, sometimes has to tweak the screen-printing source images with PhotoShop software in order to make the images wrap appropriately around the two-inch-thick panel frame edges.
  • http://www.jlconline.com/Images/1742001501_soundproof-panel-9_tcm96-2162243.jpg
    true
    600
    A crew member shows the completed panel before wrapping it in plastic for storage, then delivery to the job site.
  • http://www.jlconline.com/Images/1395317386_soundproof-panel-10_tcm96-2162242.jpg
    true
    600
    On site at La Famiglia Giorgio restaurant in Boston’s historic North End, a crew member drills into the mortar of the restaurant’s brick wall in preparation for hanging a “REVRB” sound-absorbing panel in place.
  • http://www.jlconline.com/Images/615463481_soundproof-panel-11_tcm96-2162241.jpg
    true
    600
    Tapping a plastic anchor sleeve into the hole drilled in the mortar of the brick wall. The soft hundred-year-old mortar in the restaurant’s brick walls was crumbly and tricky to work with.
  • http://www.jlconline.com/Images/240583747_soundproof-panel-12_tcm96-2162240.jpg
    true
    600
    Panels for the ceiling of the restaurant were not screen printed, but instead were wrapped in a complementary, but unobtrusive color to blend into the background. A relatively small area of ceiling and wall panels is sufficient to dramatically reduce noise levels in a public space.
  • http://www.jlconline.com/Images/2109335538_soundproof-panel-13_tcm96-2162239.jpg
    true
    600
    A crew member screws into the mortar joint of the brick wall to secure a “REVRB” panel in place.
  • http://www.jlconline.com/Images/1823512749_soundproof-panel-14_tcm96-2162238.jpg
    true
    600
    The crew screws a pair of “REVRB” panels into the brick wall of the restaurant. Using art chosen by the restaurant owner and screen-printed onto appropriate fabric, then attached to the sound-absorbing fiber-lined panels, enhances both the esthetics and the auditory comfort of the dining area. The same method can be employed in many kinds of public space, from doctor’s offices to conference rooms, classrooms, home listening rooms, or auditoriums.
Joe Drago was a general remodeling contractor for years before he learned about soundproofing. But since he started the soundproofing arm of his business, New England Soundproofing, the sound control specialty has become a highly productive niche for Drago's company. Besides installing sound-control measures in homes and businesses, the company also supplies the necessary materials to the trade, and instructs contractors in soundproofing methods. Drago still does kitchen and bath remodels, room additions, and similar work in the Boston area; and he says his crew's general remodeling capabilities come in handy when a soundproofing problem calls for demolition, framing, roofing, or finish work.
Retrofitting sound-control solutions into the party walls that separate condos and apartments in multifamily businesses is a steady bread-and-butter market for New England Soundproofing. But there's also demand for noise abatement on the light commercial side. Case in point: the sound-control panels Drago's company recently fabricated and installed for La Famiglia Giorgio's, a popular restaurant in Boston's North End (see slideshow).
  • Joseph Drago of New England Soundproofing holds a finished REVRB noise-absorbing panel with a screen-printed art surface at his company's Waltham, Massachusetts, shop.
    Joseph Drago of New England Soundproofing holds a finished "REVRB" noise-absorbing panel with a screen-printed art surface at his company's Waltham, Massachusetts, shop.
  • A crew member builds one of the fiber-insulated panels on a work table at the shop.
  • the crew hangs panels on the echoing brick walls of a North End restaurant, where the product will provide visual interest as it quiets the space.
The owner wanted to quiet the space, but the restaurant's brick walls and wood ceilings allow noise to build in the space on a busy night. Drago solved this problem with a half dozen fiber-filled panels covered with screen-printed art chosen by the restaurant owner from images available on the Internet. The result: an urban graffiti-themed art show for the restaurant's brick walls that looks good and makes an artistic statement, even as it softens the auditory ambience for diners in the space.
Drago uses a computer program to analyze the noise potential in public spaces, and to specify the square footage of sound-absorbing panels required to reduce the noise to a comfortable level that's compatible with work or conversation. "The program gives us a number," says Drago, "but we typically reduce that by about 20% based on our experience." The hanging-panel method is effective for conference rooms as well as work spaces; in restaurants, it is often used in kitchens as well as dining areas, to improve the working environment for chefs and waitstaff. Drago has trademarked his custom-built panels with the brand name "REVRB" (short for "Reduce Echo, Voices, Reverberation, and Background noise"). Panels retail for $150 or $200, depending on size; adding screen-printed art on special sound-permeable fabric adds another $200 to the per-panel price.
Drago's own office space provides a convincing demonstration for customers: At his shop are two small furnished office rooms side by side, one equipped with a few hanging REVRB acoustic panels, the other with bare walls and ceilings or ordinary art and decoration. For a visitor, the contrast is striking: Tthe office with the sound-control panels is quiet and free of echoes so that quiet speech is easy to hear. The untreated office next door is noticeably louder and conversation is more difficult. The sound-control panels mounted on walls and ceilings in the treated office are small and unremarkable, covered with a neutral colored fabric or with screen-printed art--until the panels are pointed out, a visitor would not notice them.
JLC's Coastal Connection went to Drago's wood shop in the Boston suburb of Waltham, Mass., to see how the sound-control panels are constructed in the shop. Then we went along to the job site to see the New England Soundproofing crew install the panels on the brick walls of the restaurant. For a look at the process, see the slideshow above.
