Adobe Stock / jdoms
Adobe Stock / jdoms
Construction job openings increased in September year over year (YOY), according to data from the U.S. Bureau of Labor Statistics' (BLS) Job Openings and Labor Turnover Survey (JOLTS). The number of job openings in September was approximately 40,000 higher than the 299,000 estimated unfilled construction jobs in September 2018, according to the National Association for Home Builders' (NAHB) Eye on Housing blog. While increasing YOY, the count for unfilled construction jobs decreased on a month-to-month basis.
The open position rate (job openings as a percentage of total employment plus current job openings) dipped to 4.3% in September, after reaching a cycle high of 5.5% in April. On a smoothed, twelve-month moving average basis, the open position rate for the construction sector held steady at 4.3%. The peak (smoothed) rate during the building boom prior to the recession was just below 2.7%. For the current cycle, the sector has been above that rate since October 2016.
The overall trend for open construction jobs has been increasing since the end of the Great Recession. This matches NAHB and other survey data revealing that access to skilled labor remains a top business challenge for builders, affecting a broad set of occupations. However, more modest growth rates for housing construction for 2019 and 2020 are likely to place downward pressure on construction job openings in future data releases. That is, 2019 may mark the year for which the job openings rate for construction levels off, albeit at elevated levels. This would nonetheless be a continuing sign for the need for additional worker recruitment into the industry.
The construction sector hiring rate, as measured on a twelve-month moving average basis, held steady at 5.3% in September. The twelve-month moving average for layoffs ticked up to 2.6%, continuing a rising trend in recent months, likely connected to some market churn associated with housing affordability headwinds.
Read More
